I am currently testing event orchestration configuration via API. The rule-config via API is fine, but in order to use it, event orchestration first has to be activated per service. The default is “Event Rules”, see image below
How do I switch from rules to orchestration via API, I can’t find a proper setting.
It is not possible to rebuild or reorganize the Service-Structure another way. I would like to fully automate this configuration and not leave it in a semi-automatic state.
The corresponding entry in the docs:
Thanks and kind regards
Daniel
